Adam,
It's more the case that people farkup their standard street cars handling with half baked ideas re: tyres and suspension. They are often putting mismatched parts together, assuming that if itsenough for a race car its good enought for their car (and will make it faster).
Very low profile tyres are more a cosmetic gimmic than an actual performance enhancer. At best it does nothing and at worst it just doesn't provide the feel and grip of a little taller profile.
I have driven a couple of skylines with coil overs and wider aftermarket rims and tyres and can only say that most would not keep up with my stockie aound corners.
The atessa system or any 4wd helps no argument, but the concept of sidewal flex (ideally on tyres designed to do this) is just as important irrespective. GTR's will go quicker on slicks and that is the model of sidewall flex you try to copy with street tyres for the drags.
Originally posted by KILLER-T
Hi ya Brett if you are buyin the re540s for the drags then dont bother the side walls are way to hard to get any advantage from them on the 1/4 mile but for a track tyre they would be great.I cant tell you what they are like in the wet but on a dry road the are the best thing i have used.The only thing i dont like about them is the amount of road noise they make
Thats his excuse for poor drag times :P
I thought RE540's were sticky maybe me and you shoul swap i have some rippers ;)
:bahaha:
Originally posted by XRW
Gts its more that 540's react to the VHT and do the opsite and become more skatey than they do grippy..
I don't know who told you that but, it sounds like bulldust. Or perhaps they meant doesn't become as sticky as other tyres or even 'they are sticky to start with and the vht doesn't add much extra'.
Vht makes rubber compound tyres 'sticky' even tyres with silicone content. We found some tyres better than others in terms of responding to VHT (they all got more sticky tho'). Back in the days when you rigged a squirter bottle over the rear tyres so the officials couldn't see it when you did the burnout on street meet days (they still seem to skim on track treatment these days too).
    • The part where you claim the car "is done" means you won't...
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
