Thanks Justin, my young bloke wants it, any ideas on how much to frieght to Burnie?
NO waccas budy... I didn't think you were that old bud, ha ha ha.
Who's picking it up? It's fairly long thats all. The engine pipe, eg dump to diff is all one piece.
https://www.sau.com.au/forums/topic/128011-pleze-delete/#findComment-2368389
Yeah! hold my age well, aye :happy:
A mate of his is taking a car or something to Hobart on a trailer tonite.
You should see him tomorrow some time.
Thank again.
https://www.sau.com.au/forums/topic/128011-pleze-delete/#findComment-2368484
Yeah, the turbo's still hidden..... really well. I should just weld a turbo to the ex-man and advertise it as an "SR20 with turbo"
4.5k ... not that keen. Better than 3k some stooge offered me yesterday! Ha ha ha...
https://www.sau.com.au/forums/topic/128011-pleze-delete/#findComment-2377255
would give you more if it had 4 doors... not helpful though sorry!
Good luck!
P.S. sell me those subs! :P
Well BG Didn't call me today to pick up the amp... so Amp and Subs are all yours $200 bro
it has got 4 doors todd thier hiding with the turbo. hehe
Funny fkers... aint ya!
It's also hiding a gass kit, T51R SPL, 2.2lt stroker kit, Auto and a 9 sec pass there some place.
https://www.sau.com.au/forums/topic/128011-pleze-delete/#findComment-2378128
i offered on it a few days ago. yea i sold the magna and got a 4 door skyline. sorry i couldnt help with buying your silvia but the guy i brought the skyline off traded plus cash forr the magna. about the only way i would get rid of it.
you dont have any manual gearboxes floating around do you?
https://www.sau.com.au/forums/topic/128011-pleze-delete/#findComment-2378522
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
