Hey everyone.
Well as the title states i have a nos kit for sale
It has been used for a short time but is in excellent condition.
This is a wet kit.
Kit includes:
*10lb NOS Bottle
*Electric NOS Bottle Heater
*NOS Bottle Blanket
*NOS - Super Powershot Nitrous Solenoid
*NOS - Cheater Solinoid
*NOS - Chrome Housing Polished Base Nitrous Solenoid
Cheatertm Nitrous Solenoids Excellent For Supporting Higher Levels Of Power With Nitrous. Flow Rate: Up To 250 Hp Amp Draw:10 Amps Inlet/outlet:1/4 Npt / 1/8 Np
*NOS fogger Jets etc
*3 different nitrous pressure gauges, one is on the 10lb bottle
*All Braided Lines.
*Fully detail NOS Owners Manual.
PRICE: $1000 ono
Contact me via PM or mobile (0419 15 45 15)
Cheers
Guesty
Edited by GuestyR33
https://www.sau.com.au/forums/topic/128016-nos-kit/
ill swap you for my 18" 350z track wheels with $250 cash my way.
wats the tyre tread like?
condition of wheels?
scratches etc?
happy to do cash adjustments to anyone else interested.
https://www.sau.com.au/forums/topic/128016-nos-kit/#findComment-2386272
i can get them off the internet for less than $800 so alot of people are not going to pay $1000, especially if it's used, considering you have got extras id offer $600
It was installed on the car for just under a month.
But actually only used twice.
In mint condition.
The gauges alone cost quite a bit, plus the nos heater and bag aren't cheap.
I'll take $850 plus post.
https://www.sau.com.au/forums/topic/128016-nos-kit/#findComment-2437452
In mint condition.
That sounds resonable, jus a few questions, when instaling it who in melb. did it for you? did you have to advance ignition timing? or did you need any other extras to get it going?
https://www.sau.com.au/forums/topic/128016-nos-kit/#findComment-2440160
Hey bud
Not sure bout the ignition timing... Was never told bout it.
No other extras that i know of were needed to get it going.
Just nos in the bottle lol.
I had the car tuned at the time though, because i installed an apexi power fc at the same time.
My mechanic installed it all. But he works from his home garage. Not a known work shop sorry.
Cheers
https://www.sau.com.au/forums/topic/128016-nos-kit/#findComment-2440172
I have a set of 18X8 chrome rims to suit Skyline, Awesome rims, let me know if you want a pic.
Cost $3,000 brand new 3 years ago.
I will swap for nos kit.
Very interested mate
Can u send pics to [email protected]
Also can you pm me your mobile number.
I'll give you a call about it.
Cheers
Guesty
https://www.sau.com.au/forums/topic/128016-nos-kit/#findComment-2446121
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
