  • Replies 108
Posted Images
Does it look fixable? i also bent the passenger side rear control arm and some rod thats part of the HICAS stuff..........
Am trying to source parts at the moment.
Is ther any chance i can scab a lift off someone if i dont get my car back on the road? but its a 99% chance the car will be back on the attack for teh nasho so relax, its not hard! anyhow have a winfield!
ouch.. New rims time ;)
remove hicas all together lol
im sure someone will give ya a lift...
Yeah i agree - new rims
AND get rid of HICAS while fixing whatever's broken in there
So far, there's 4 people scabbing lifts for this one :(
So far, there's 4 people scabbing lifts for this one :O
4 People! DAM! Hopefully i will get it all soughted by Friday night - just like the last nasho run....... Had a fcuked thrust bearing and had to change it on the day FUN FUN FUN!
:O
What ze fick
Someone is going to get stabbed muhahahah
Can i get a lift off someone aswell now ? :lol:
What ze fick
:P
Unlucky - i just forked out 2 grand to fix my car from been a tool and running up that dudes ass whilst checking out a hot chick and now this. :rofl:
Slide bring on teh crayons! If my car is back on the road you riding with me bish! fingers crossed!!!!
Unlucky - i just forked out 2 grand to fix my car from been a tool and running up that dudes ass whilst checking out a hot chick and now this. :huh:
:sorcerer:
hahahahah
w00t be there soon
Everyone go it will be fun
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
