Hey guys.
Just wondering if anyone is running either of these garrett turbos on there gtrs?
How do they perform ?
Does the larger GT2860R- 7s have issues with shuffle down low and how responsive are they? e.g when do they start pulling from and when do they get onto full boost ,say 1.4 - 1.6 bar.
Here is where im at,I have an engine thats built for a solid 700hp with fueling to match,running power fc as my computor.
My goal is high 300kws or even low 400kws at the hubs (hub dyno) would these turbos do this?Iv read that the GT2860R - 5s are good for 360hp apeice with almost factory response in spool rate and the GT2860R- 7s are rated to 400hp each , now thats on paper but what are you guys getting with these tubbies? A single is not an option for me at this stage and I want to keep with bolt on low mounts.
Any help will be greatly apreciated
https://www.sau.com.au/forums/topic/128443-gt2860r-5-vs-gt2860r-7/
The 707160-5 in a pair combination is good for 700hp at all fours as proven to me on a dyno. Brisbane tuning and turbo centre.
The -7 will come one boost slightly earlier and sharper. The -5 has a smooth deceptive power curve.
The -7 is basically just the N1 whereas the -5 is an upgrade to that turbo. People who I have sold these -5's to have been wrapped in their performance. Most of whom had come from such turbos as the -7 already.
would love to know what else is done to this car....because that figure sounds a bit too high for those turbos. they're only rated at 350hp so how you can get 700awhp out of them would make for an interesting read.
Garrett publish the compressor & turbine maps for these things (as with most of their product). Have a look at www.turbobygarrett.com under the part numbers. You can quite reasonably relate airflow to engine hp. This is actually what people are dong when the quote a 350hp turbo or whatever. Anyway, have a look.
"The 707160-5 in a pair combination is good for 700hp at all fours as proven to me on a dyno. Brisbane tuning and turbo centre....People who I have sold these -5's to have been wrapped in their performance."
3li3 32
I'm guessing these -5s are on RB26, 700 @ all 4 WOW; what are the specs??? I thought somewhere around the mid to low 500s at the wheels was about it.
DVSGOD
I have -5s on my 89 R and they are great, they really start pulling hard at around 4K. I'm making 412rwhp on an internally standard combo...an excellent purchase
Cheers for your replys guys :no:
And as Steve _gts4 has rightfully pointed out the -5 is in fact the bigger of the two
I got my info from here http://www.turbos.co.nz/garretttake2.html but it seems they have the write up on each one round the wrong way
Edited by DVSGOD
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
