I feel that my brief love affair with my R33 Skyline must come to an end. It is a great car, but I miss my V8s.
Here is a basic run-down:
Year: Apr 1996
Model: R33 Series 2 GTS-T
Trans: 5 speed manual
Colour: Black
Kms: <74000
Rego: May 2007
Standard Skyline features:
*Factory Body Kit
*4 piston brakes
*Climate Control Air Con
*Power Steering
*Power Mirrors
*Power Windows
*Limited Slip Diff
Added Extras:
*17" SSR 5 spoke wheels with good tyres
*Lowered suspension
*turbo-back exhaust system
*HKS pod filter
*Cusco front strut brace, and rear strut brace
*Pioneer MP3/WMA CD player, Fusion 4ch amp
*Brand new Exedy heavy duty clutch
This is an awesome example of an R33 series 2. The car made 178rwkw recently, and is completely stock apart from exhaust and pod filter. Stock turbo, computer, boost, intercooler, everything.
May consider trade for VT SS, VX SS, VS V8 ute or VU SS ute, manual only.
Asking $16500 firm for quick sale. If the car that I want sells, price will be $17500. See the link in my sig for pics.
I also have an ARC intercooler and Apexi boost controller on it's way from Japan which I will sell separately.
PM or call 0411174831 for if you are interested.
Edited by Quinny
https://www.sau.com.au/forums/topic/128528-for-sale-r33-series-2-only-16500/
I would belive this output, As I used to have an R32 with just the standard 2 litre turbo, and with just 10psi of boost, 3inch exhaust with hi flow cat, and a front mount, i made a healthy 165rwkw!
Edited by extremegtr
:laugh: Those power figures seem very VERY fishy dude..... That sorta power is something you would get IF u already had the ARC fmic and boost controller already fitted... Good luck with the sale by the way....
I have the dyno sheet to prove it mate. It was a little higher than I expected, but that is what the dyno said.
thats a good price ur asking ill get in contact with u when i sell my car unless u want a swap plus cash good luck with sale
Not really interested in a swap unless it is for a Commodore. Let me know if you are keen.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
