I searched the site and found several thousand results, but not a simple explanation.
Ive seen a couple of R32 GTR's with the front corner indicators (next to the headlights) clear instead of the usual amber. Just curious wether you can buy these, make them and who you have to sleep with in order to find out. Also are they still legal in NSW?
Cheers boys....
https://www.sau.com.au/forums/topic/128717-r32-clear-indicators/
because they sit in different brackets, are of different dimensions and mount up to different guards.
ie. they're not the same.
GTR indicators have a single piece moulded plastic cover, this was only available in orange from factory. Aftermarket clear ones are simply a clear version of this cover.
GTSt indicators were initially sold in clear with an orange bubble (ie a 2 piece cover), then in the second series R32, both pieces were made orange, so that they looked like the GTR ones. You can buy aftermarket ones that have both pieces clear, or buy a series 1 indicator and smash out the orange inside part and make yourself a clear indicator on the cheap... although the small bubble will still be orange.
Gtr ones have a different shape to match the fatter guards on the gtr
Cool cheers!
  • 1 year later...
Tools required:
Dremel
Hot Glue Gun
Clear plastic from an office Fluro tube cover (steal one if you have to)
Stock Indicator covers
How to DIY your own Clear Indicator Cover:
-Remove stock indicator cover and take to a new clean work bench.
-Use dremel to remove the crappy orange coloured cover of the original light.
-Now, with a clean lower bracket, you can measure the clear fluro cover.
-Using a dremel on the cover, cut a section to cover exactly the section that you have removed the coloured cover from
-Meassure the inside of the clear, and cut this out as well (the first section is for a spacer to make room for the globe).
-Once the lower section is made, glue it flat section down to the indicator light.
-At this point, test-insert the globe and make sure there is clearance, if not, do this process again to give you more clearence.
-If you have clearence, then the next section of clear plastic you dremel-cut will be dimple's down, and will need to meet with the section/sections already glued on the indicator light, then cut with dremel and hot glue-gun this down as well.
Allow time to set, then fit the globe, re-install and repeat for the other side.
I have seen this done on a Toyota Soarer and it looks the goods, also complimented with Phillips clear/silver look organge indicator globes, as they turn clear/silver when not illuminated.
So if you cant find your own clear-cover indicator lights, make your own :whistling:
B.
So if you cant find your own clear-cover indicator lights, make your own :thumbsup:
B.
that's great... as long as you don't have a GTR :D GTR indicators are single piece moulded plastic, and they're different in shape and fitment to GTS/GTSt ones which you can mod the way you've described.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
