some GTR parts available..
ARIES forged pistons with teflon coated skirts, std bore size...complete with pins and spiralocks...used (5000klm) $500.
GTR cyrotreated shotpeened closed and honed conrods, complete with ARP rod bolts... good for over 450 AWKW+...$500.
CLUTCH Jim Berry race item with flywheel, good for over 450 AWKW+ done 2 drag passes...$800...SOLD PENDING PAYMENT
TOMEI sump baffle kit...bolt in sump upgrade..$350
will do the rods and pistons as a set for $800
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/128740-gtr-engine-parts/
what is required to fit the sump baffle in a nutshell? possible to do at home without too much hassle? for RB26 GTR? do we expect extra capacity? very interested.
easy fit...straight bolt in...no hassle at all
you need to take the engine out to do it. definately not an easy DIY. and no extra capacity just keeps oil around the pick-up. BUT it is highly reccomended if you are doing track work.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
