Mod question
Guest R33 GTR V-SPEC
Hi guys,
I recently got an R33 GTR Vspec and im planning to modify it with the following:
1. 3.5" turbo back exhaust
2. Pod filters with carbon fibre heat shield
3. Apexi power fc
4. Apexi boost con @ 15psi
5. Larger intercooler.
With these mods does anyone have an idea of what power id be making @ the engine and approx what 1/4 mile time it would run?
https://www.sau.com.au/forums/topic/12886-mod-question/
Hi R33 GTR V-SPEC, The other guys have covered the power and 1/4 time pretty well. My suggestion would be don't change the intercooler, the standard R33 GTR intercooler is good up to 300 rwkw. With your plans you won't be anywhere near that. So keep the response up and stick with the standard intercooler.
The only weakness at your target performance level will be the clutch. Heavy, big power and 4wd puts a lot of load on the clutch. Standard clutch won't last very many launches. We use OS Giken twin plates for your sort of power level.
Hope that helps.
https://www.sau.com.au/forums/topic/12886-mod-question/#findComment-255370
Similar to what I'm going for, with that setup you should be pumping out around 240-250 rwkws, 330kw+ @ flywheel. I agree with sydneykid, don't change cooler, better spend that money on a twin plate clutch, standard one won't last with that sort of power and hard launches.
I'm going for nismo twin plate, from what I've heard they're not harsh on the left leg.
Also expect a mid to low 12 with that sort of power on the 1/4.
Hope that gives you a fair idea.
Cheers
https://www.sau.com.au/forums/topic/12886-mod-question/#findComment-255436
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
