I have a lid on its own in good nic. $25
Got the heater unit too $50
I can post it for you.
Hey im after these items. Please post what you have and the price. Im in WA aswell.
- Centre dash console lid (just the lid)
- Drivers side window control buttons
- Air con control unit
- Drivers side window motor
- Series 1 steering wheel
https://www.sau.com.au/forums/topic/129342-r33-parts/#findComment-2392151
Hey mate.
I have an r33 gtst series 1 steering wheel...
Pm me with an offer if ya interested.
its in excellent condition.
cheers.
https://www.sau.com.au/forums/topic/129342-r33-parts/#findComment-2393466
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
