Depending on car situation i would like to enter if i have mine either going again (or if i even have it) but i'll be there to take a few happy snaps and some footage again.
Should be an interesting field again this year i reacon!!!
With David Owens Evo 4 suffered an engine failure on the weekend I was going take over his spot, but thanks to a re-design of the course with a chicane in the only straight a GTR is now uncompetitive so I'll be spectating... the Domain HC is now Evo and STi heaven.
Yeah a couple of us were talking about this yesterday, sounds a little gay if you ask me but hey they have to do something to slow things down i guess!!!
Funny thing is i think it will only cause more people to spin/crash and do more harm then good with the placement of the chicane!!!
Entry list looks interesting and should be an OK event but it wont compare to the previous years, the track just doesn't cut the mustard if you ask me :D
GMB
The previous indicent on that 'straight' was more to do with low performance driving that high speed... a basic TR7 is far from a fast car!
GMB
Guys,
I agree the course is far from ideal, makes one think that there must be some better roads around that would suit a hill climb. Would be great if there was a southern tas hill climb series over a few different roads.
Stu, any idea if this is possible and who would organise?
Guys,
Anything is possible, its just finding the right bit of road. I would like to see the old Eagle Hawk Neck course get up again, that would be good for most cars. 500 Car Club ran that one. Dysart was another old one that I'd previous run at (also 500CC), that was little boring as it wasn't very technical. If anyone has a fav bit fo road that is anywhere upto 2k with minmal residents speak up!
Yeh, Im not happy about the Chicane idea. Ive voiced my opinion but havent got a responce as yet ! Seems to defeat the purpose a little if you ask me. Im told it will make for a change back to second gear. My clubby revs to 9200rpm so for me its back to first. What a pain in the ar....e. But I will still have a good day if the rain stays away
Yeh a new track would be great if we could find one.
Cheers
Greg
:nuke: yeah i know who crashed and i think it just comes to show that the people involved obviously look at it from a drivers point of view.
How long have they run the DOMAIN course and how many people have crashed on the straight (still got me buggered how you spin on a straight stretch of road :huh: ) but anyway its been done now!!!
Guys,
I'd put my hand up to be in on that...
There are plenty of great roads that are ideal for it and i think a mini hill climb series would be awesome. Like i said i would put my hand up to do something like that and im more than happy to go and test all the roads :/
Cheers
Greg
Thats going to be fun for you Greg seeing as the box's in the clubman's aren't all that user friendly trying to get back into first :)
I suggest holding it in 2nd and clutch kicking :rofl:
what about us poor northerners :(
Sounds like someone needs a :huh:
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
