well its not very long admittedly but have you ever put your hand on it after having been for a drive.yes the air is going thru very quickly but your still getting an awful lot of heat soak in there.same as your airbox does & its not as close to that damn hot turbo as the inlet pipe.besides for the little cost involved why not every few degrees colder the air is the better.
cheers
warrick
Guest saiyaman
howdy peoples, Ive been reading your posts....... Im sure that the partition would help with temperatures from the engine but through the tests that you guys have done it looks like the most benefits came when you reached certain speeds and that's when the air was the coldest..... so what I mean is if you could force more air into the box or pod at lower speeds in the first place then wouldn't that give you the most gains?? has anyone tried making a larger feed where the air first enters and testing what kind of difference that makes....I looked at the bottom of my bumper and the inlet is tiny, what do you guys think?
Originally posted by warick
the car just seemed that much more responsive & stronger, if that makes sense?
It makes perfect sense now :D
To all those people with a stock air box and thinking about ditching it for a pod, dont!!
I initially had the stock box on with crap filter. I then upgraded to a pod (out of peer pressure really) and was impressed with the performance gains at high revs. I was at Autobarn on the weekend and decided that I'd give the panel a shot just to get some personal closure on the issue.
After driving the car round all day with the new panel filter in I cannot understand how I put up with the pod for so long. The car gets-up-and-gos heaps better. The best way to describe it is to have a look at the boost gauge. The needle jumps when you push the throttle, before it was a little limp. A lot more throttle response :uh-huh: and out performs the pod at every rev!
Smoother, quieter, stronger application of power... How can anyone argue?!?!
Moral of the story: Pods are a complete waste of money without CAI & induction noise is bloody annoying!
You can buy heat proof cold air box foam from Unique Auto Sports. It comes with a template drawn on it so all you have to do is cut it out and attatch it. Its $90 and comes with a tube of Silicon to get perfect seals round your turbo piping and a rubber strip for along the top to cushion it up against the hood.
You may be able to source the foam yourself...its black/grey with silver foil type stuff on one side. I bought it but didnt ever get round to fitting it and ended up selling my car when I came O/S.
I would have expected a good result too as I had 198kw/atw with only a little more boost, full exhaust (turbo back) and a K&N. That cold air was much needed!
I've have just upgraded my K&N panel (now for sale if anyone interested) to an Apexi pod (had no choice, new front mount crossover pipe fouled) and have made a box for it but it is still noisy as hell at half throttle accelleration between 3000-4500rpm. Above that it goes fairly quiet again. Whats up with that? Is there any way to make it quieter?
Ok, despite the horrid review by riggaP, YBSLO4, can I still get one of those aluminum cai things your making.
Why arent I reverting back to panel you may ask? well, I bought the a trust pod filter recently, and I stand by it.......
YBSLO4, how should I go abouts in getting hold of one. Thanks!
Here is a pic of the new box I made for my Apexi pod. After lining inside with a layer of 10mm insulation foam with silver heatsheilding on one side I am more than happy with the result. Much quieter than without and a definite improvement in response. Took me a couple of arvos to knock it up out of aluminium plate, total cost under $30.
Zman: Both my pod and panel are K&N and are made from the same material so I guess it comes down to surface area. The panel is only marginally smaller than the pod and I doubt anyone would be able to feel the difference.
The panel feels like it flows HEAPS more air than the pod without a CAI.
    • They're all horrible. X-Trails have had a nasty sounding 4cyl since forever, no matter what engine family it came from. The CVTs only made that worse. Then the whole Renault thing only made every Nissan that was contaminated by them even worse again. The only fun I've had in a X-Trail was having it blown sideways across a frozen Minnesota highway at 90 mph trying to make it to the airport to get out of the frozen hellhole of Hoth. Nearly died. Was great fun.
    • Alrighty, I'll have to grab a couple pics and type out something soon in another post. I haven't driven a modern X no, this would be the first one really. Yeah the rental boxes are always cheap as chips right? So I'd doubt that anyone was handing out GTs to go and abuse. But I s'pose I could be wrong for sure. New cars these days though? Pretty unimpressed with what I see now; 20 years and all that, like you said. It just kind of worked out to have these two cars now. I'm pretty pleased with that, don't need much else. I'm sure you lads are right about the temps and for sure, you wouldn't have much time to drive 'em down there if you all were like me. I do hate sweating all over the seats though😆
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
