Gb: Brand New Z32 Afm's - $330.00 Each
Hi guys, while looking around for some new Air Flow Meters for my GTR, I have found a great deal for brand new Z32 AFM's which sees these new AFM's priced only a touch higher than what you would expect to pay for a used item.
Just Jap in Sydney has kindly offered to supply the AFM's for this group buy for $330.00 Each (Inc GST)
Tomei Z32 adapter plugs will be available as an optional extra for $49.00 each.
Important Information:
* These are genuine Bosch Z32 Air Flow Meters
* Each AFM includes a 12 month warranty
* We require 10 or more buyers for this group buy to proceed
* Express delivery is available for $10.00 Australia-wide
* The closing date for this offer is firm
Once we have 10 people confirmed on the list, the order will be placed and you will then be asked to make your payment.
Pickup will be available from Just Jap in Kirrawee, Sydney (South), when the group buy concludes, otherwise express delivery is available
Note: I have already confirmed stock availability with Just Jap
Group Buy Start Date: 15/8/2006
Group Buy End Date: 15/9/2006
Making your payment
Payments will be accepted only via direct deposit - Instructions for payment will be supplied at a later stage.
What are you waiting for? Register your interest NOW :)
BUYERS CONFIRMED:
Blitz 2 x AFM + 2 x Tomei AFM Plug PAID & CONFIRMED & POSTED
d00dz 1 x AFM PAID & CONFIRMED & POSTED
Danoz 2 x AFM + 2 x Tomei AFM Plug PAID
rbsilvia 1 x AFM + 1 x Tomei AFM Plug
FLYSLY 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
Crack 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
AcoustiK 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
_8OO5TED_ 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
pulp 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
2face 1 x AFM + 1 x Tomei AFM Plug
al_r33 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
steves180 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
babia 1 x AFM + 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
writeoff 2 x AFM
jetdat 1 x AFM & 1 x Tomei AFM Plug PAID & CONFIRMED & POSTED
darkl0n 1 x AFM & 1 x Tomei AFM Plug PAID
R334Door 1 x AFM PAID
https://www.sau.com.au/forums/topic/130308-gb-brand-new-z32-afms-33000-each/
  • Replies 117
Registering interest.
Can I pickup?
Now to find plugs for this hmmm
Vic, no need to find plugs, they can also supply the Tomei Z32 plug adapters, will append the first post shortly with details.
Also as above, pickup will be available at the conclusion of this group buy
How do i know if i need the adapter?
If you are fitting this to a Silvia, GTS-T, GTR etc, you will need the adapter plug as your factory AFM plug will not fit onto the Z32 AFM.
Ok how soon can i pay for this and have it delivered?
Looking to get one ASAP
They are ready to go, however we need 10 people confirmed to secure this price of $330.
Would you like me to mark you down as confirmed?
Yes im definately in, works out cheaper than nengun which is awesome
Thanks mate, I have added you to the list.
Will you be wanting the AFM adapter as well?
Yeh sorry mate.. im eager thats all
Its a bargain and an AFM is something that a lot of people would be due to buy so we should fill up the 10 easily and fairly quickly i'd imagine...
Not very often things go cheaper here than from greenline or nengun.
Hopefully it will arrive faster too I dont want to have to wait 2 weeks...
Thanks for organising this - great group buy
Happy to help mate.
Once we reach the minimum order (10), and your payment is processed they will be ready for pickup and dispatch straight away - A quantity of them is already set aside for this group buy :)
I will advise more details soon.
Nick
Keen on one with adapter, but a couple of q's
Would I need a tuner to hook up the plug, or can it be just adapted to the existing plug? Also, do I need to retune my ECU?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
