I have 10 full sets. $70 each set.
These are all brand new....not second hand. Will post to anywhere in Oz for this price
One set comprises 4 bushes that are two different sizes. These greatly inhance the rear stiffness of the vehicle and in most cases will improve traction and 1/4 mile times by up to 1 second. Great also for drifting as the new stiffer rear end will tend to slide more easily once traction has been broken.
https://www.sau.com.au/forums/topic/130544-pineapples/
do you have to remove the cradle to fit these or do you just lower it?
Depends on what configuration you go for?
You can slit the bushes and slot them in by loosening the subframe.
Or do it the hard way and drop the hole subframe installing the bushes without sliting them.
https://www.sau.com.au/forums/topic/130544-pineapples/#findComment-2417437
You can just remove one half at a time....to install literally takes about 10 minutes, so to answer you question, you can just lower it.
wat brand are these? where u located?
They are superpro and I am located in Brisbane's south
Got any pics? Alloy or Polyurethane?
I will get pics tomorrow ( I keep them at work )...and they are Polyurethane
I will try to sort out some installation instructions and post them up
https://www.sau.com.au/forums/topic/130544-pineapples/#findComment-2418857
  • 3 weeks later...
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
