how easy is it to install the lights? any cuttin needed or anything? i like it alot
great work
its not easy work.. couse need some metal works to do..
like an american chopers.. :O
it takes 2 days..
u can find some fotos here:
http://photofile.ru/users/dobermann/137035...p;page=lastPage
Edited by dobermann
Far out, how dirty is that area where you park!!
I'm pretty impressed by the install, it looks nice and neat, although I think I need some pics from behind with the rear bar on, because at the moment the lights look set too low for me.
interesting approach... seen it done on a ceffy in japan, but they used R33 sedan tail lights instead, and it looked like it sat flush with the ceffy body.
Nice job, nice car though.
  • 1 month later...
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
    • Have you done 10x restarts since it came on?
