how easy is it to install the lights? any cuttin needed or anything? i like it alot
great work
its not easy work.. couse need some metal works to do..
like an american chopers.. :O
it takes 2 days..
u can find some fotos here:
http://photofile.ru/users/dobermann/137035...p;page=lastPage
Edited by dobermann
Far out, how dirty is that area where you park!!
I'm pretty impressed by the install, it looks nice and neat, although I think I need some pics from behind with the rear bar on, because at the moment the lights look set too low for me.
interesting approach... seen it done on a ceffy in japan, but they used R33 sedan tail lights instead, and it looked like it sat flush with the ceffy body.
Nice job, nice car though.
  • 1 month later...
