Ive got 10 sets of clear front indicators coming in.
These are to suit the Stagea WNC34 (S1) only.
These are very hard to find and they normally retail from $100-$130.
Special Price - $70 delivered.
Finish date - 14/09/06
Payment due - 18/09/06
Buyers:
1/ Talej - paid - sent.
2/ Ska- paid - sent.
3/ wagonwheels - paid - sent.
4/ Burns - paid - sent.
5/ FLYSLY - paid - sent.
6/ StageaGirl - paid - sent.
7/ wagon - paid - sent.
8/ RSFour - paid - sent.
9/ private buyer - paid - sent.
10/ humble
11/ CruiseLiner
12/ STAGE-A
13/ qikstagea
14/ jake32
15/
16/
17/
18/
19/
20/
I'd love to, but just dont have $70 spare..... had to push it to get the clear sides, which were $50! :P But still, brand new from nissan these are worth $120 EACH!!! Not a pair of them!! This is a BARGAIN!
Got my package today... thanks! Slight problem that I'm not quite sure what I should do though... my car has square plugs and the clear indicators have round holes????? :(
Are the plugs on my car not standard for some reason? Where can I get some round ones from?
Talej - You should be able to swap the plug, wiring and light bulb socket from your standard ones to the clear ones.
FLYSLY - thanks :woot:
yep - I managed to get it all sorted out. swapped the plugs and bulbs and I had to do a little bit of filing on the clips because they were too wide for some reason. All in and looking great now.
Thanks :D
Thanks :D
Excellent :woot:
Dude you are a dead set LEGEND!
Got mine today, had to cut a tiny bit out of my front bar as the two prongs didnt quite fit, the top one on the standard part is only half as wide, a two second tiny cut with a stanley knife and BAM, swapped the plugs and bulbs and put in.
Done, THANK YOU!!
Done, THANK YOU!!
Excellent :(
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
