SOLD
FOR SALE IS THIS IMMACULATE TWIN HIGH MOUNT BOLT ON KIT FOR A SKYLINE R32 OR R33, COMES COMPLETE WITH
*TWO KKK K26 TURBOS IN IMMACULATE CONDITION WITH NO SHAFT PLAY AT ALL,
*TWO BIG EXTERNAL WASTEGATES WITH SCREAMER PIPES,
*BLITZ MANIFOLD IN TOP CONDITION (PERFECT WELDS NO CRACKS),
*ALL GASKETS REQUIRED FOR INSTALL ARE INCLUDED,
*ALSO INCLUDED IS TWO K&N POD FILTERS WITH PIPES ALREADY PROFESSIONALLY ATTACHED TO TURBO HOUSINGS,
*2 PIECE DUMP PIPE FROM TURBOS TO CAT INCLUDED ALSO
HAS MADE OVER 400KW AT ALL FOUR WHEELS ON ONLY 22PSI WITH MINIMAL MODIFICATIONS IN AN R32
DONE ABOUT 5000KMS SINCE NEW. IN IMMACULATE CONDITION
REASON FOR SALE IS I AM STRIPPING DOWN CAR AND GOING FOR A FULL DRAG SETUP
ITEM IS LOCATED IN SYDNEY AND PICKUP IS PREFERRED HOWEVER, IF REQUIRED. WILL POST AT BUYERS EXPENSE
PM ME OR EMAIL AT [email protected]
https://www.sau.com.au/forums/topic/131860-sold/
  • Replies 46
Posted Images
what turbos are they
when was she on ful boost
and dyno graph please
THEY ARE KKR TURBOS K6 SERIES(THEY HAVE A PLAQUE ON THE FRONT OF THE HOUSING I WILL CHECK TO SEE WHAT SERIES FOR SURE)
NO DYNO SHEET AVAILABLE BUT BY MEMORY FULL BOOST BY 4250RPM.
https://www.sau.com.au/forums/topic/131860-sold/#findComment-2441887
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
