Guest | hype^ |
dont get me wrong im dedicated to this club..
but i aint putting no stickers on my car body!:O
get 1 that will fit the windscreen nicely..
like maybe a big 1 for the rear and a smaller 1 for the front :P
that would be nice..
like maybe the rear 1 saying "Skylines Australia" on the rear and a smaller "http://forums.skylinesaustralia.com" on the front..
or some sh*t like that.. :uh-huh:
for design i wouldnt mind the logo on the upper of the screen.. as it is.. :O
Birty it's not that nothing has been done, it's just we wanted to try and get the paperwork side of the club organised before we worried too much about stuff like stickers etc. A car sticker will be included in your membership fee, so we need to have the club going before we can send them out to anyone.
A few promotional banners are being made up atm (for across the back windscreen - see attached pic)...we will see what they look like on a car, if they look cool, they could possibly be the proper sticker...
But as kabab said all design ideas are very welcome! Please keep them simple and easy to make into a vinyl cut-out sticker :P
It's still being done state by state is it not ? Cause I don't know what's going on up here, hopefully come Skidpan we'll be able to sit down and talk it out, I know Squizz and cam are coming so all should be good hopefully. But I want a sticker, I don't mind paying for it. But i'm bloody well impatient sucka's. When they're ready I want one, i'll pay, no problems.
you spoilt little brat. (oooh nah. i forgot my powerball ticket. i just remembered. doh) each state is responsible for their own club so yeah, talk to cam or j at the meet you guys are having. the stickers shouldn't be too much longer and we'll have this thing going where you can buy one now and if/when you join you get the same amount deducted off of your membership payment
Originally posted by ex-static
well, that puts a stop to that then, doesnt it.
hey ex-static, don't stop...your designs are good! I like the second one a lot :)
Nothing has been decided for the "official" sticker, so if you have any more ideas, keep them coming! Not sure if we want more than one colour though, will have to look into cost :)
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
