im looking for a series 2 days front bar i spose its like looking for unicorn poo but hey ill put it out there
im just not into the other bars on the sites and it will still retain the sleeper look.any help would be apreciated.regards mike
https://www.sau.com.au/forums/topic/132292-wanted/
  • 3 weeks later...
I was after a DAYZ front bar for my series 1 and found them near imposiable to get so i settled on one from motovation imports on the gold coast QLD.It's the closest i could find that lookes simler to what i wanted and the whole kit cost $850.oo pick up. Check out www.motovationimports.com.au they have photoes of them on a series 2.
https://www.sau.com.au/forums/topic/132292-wanted/#findComment-2537871
for $850, thats not that bad an idea - with the Dayz look, you have plenty of space for a medium-sized FMIC and can use return air feed piping route (for legalities).
I hacked the centre #plate section off tho on my S1 :D meh
https://www.sau.com.au/forums/topic/132292-wanted/#findComment-2541665
  • 4 weeks later...
I am pretty sure that the guys at Motovation took the mould from my car before I picked it up. I love the look, and its easy to live with (I scrape my XR6 Turbo Bar heaps more than the Dayz bar).
https://www.sau.com.au/forums/topic/132292-wanted/#findComment-2621392
I got a S1 dayz front bar from slidewize, cost $800 delivered to my door, little expensive, but as you said mike, like finding unicorn poo.
I have seen quite a few S2 dayz front bars on there.
https://www.sau.com.au/forums/topic/132292-wanted/#findComment-2634231
yup they are 2 dear tho i cant justify those sora dollars
https://www.sau.com.au/forums/topic/132292-wanted/#findComment-2635023
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
