From my memory the R34 GTT makes 148Kw@wheels in stock form
I dont have an at the wheels figure for an R34 GTR but in the attachment is a dyno-sheet for an R34 GTR N1 (more powerful than your average R34 GTR - although still quoted at 206Kw@flywheel) which states on a mid-30s-degree day the N1 made 214Kw@wheels.
As was stated earlier, if a Japanese car is quoted at 206Kw, it is more than likely making considerably more than that.
R34 GTR M-Specs in stock form are rumoured to be making 240+Kw@flywheel.
Apologies for not directly answering the question, and an even bigger apology for putting an article up which features a Commonwhore/Bommadore , and for the crappy quality of the article. Hope the info helps....
Source: Wheels Magazine April 2002
  • 5 months later...
