1993 R33 gtst.
5 speed manual
193 rwkw (chiptorque)
safc-2
apexi power intake
600x300x75 cooler with alluminium pipes
3 inch exhaust
lightened alloy flywheel
ceramic button clutch
stock rims
alpine head unit
everything else i can think of is stock
71,000kms
i am the first owner in australia
reg til 10/06
$17,500
Edited by 30et
https://www.sau.com.au/forums/topic/132413-bris-1993-r33-gts-t-black-5-speed/
  • 1 month later...
how can it be chipped ive got a mate that puts chiptorque chips in and he said because the r33 computer cant be tuned u cant put a chip in it?
a bit over priced dont u think. a stantard 33 gtst
How do you call 193rwkw stock?
safc-2
apexi power intake
3 inch exhaust
Although price is up there, its certainly not stock!
safc-2
apexi power intake
3 inch exhaust
i agree.
i looked at a lot of skylines before i bought this one, and this one was by far in the best condition. people who look at wont think its over priced
  • 4 weeks later...
Hay mate, what boost does the car run? Also whay condition is the motor in, any problems with cold starts? ect. Oil usage?
I have 15K email me at
[email protected] if you want to talk.
Also can you send some more pics to the above address.
Edited by WogsRus
  • 4 months later...
this car is still for sale
FMIC, 3" turbo back, tuned SAFC2 193rwkw on 10psi
cermaic button clutch, lightened flywheel
immaculate car, 72,500km's
pm for my mobile number or further enquires
Edited by 30et
  • 2 months later...
  • 2 months later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
