ITS TIME TO GO......MRHELE
Well people its that time again where i need to part with the car for personal reasons.
Mods as follows..
R33 1994 model compliance 2002.
CRD Front mounts with JJR Pipes - Brand new
Hi flow turbo by GCG
3inch Exhaust all straight pipe and i mean all! with canon on back.
Simota Pod.
GTR Injecters
Walbro 255l pump
new fuel tank
Daiken Semi organic clutch and HD pressure plate
Apexi power FC
Car serviced every 3000k with genuine nissan filter and Motul oil.
Exterier has been resprayed about 1yr ago but needs a buff as its straight off the gun. This will be buffed prior to me letting the car go.
M spec side skirts
G4 Coil overs.
19x8 and 19x9.5 Zennetti Kaotiks with brand new tyres all round.
New battery.
Inside the car is a whole different story. Everything and i mean everything has either been rapt in leather or suede, this meaning from roof to carpet dash to parcel and soon the boot.
Custom carpet with suede piping
JVC DVD unit with 7inch screen fold out.
Pioneer Bullets 6inch splits
2x12in DD subs in box
1x800wrms Monoblock Response (brand new)
1x500wrms 4 channel Response (Brand new)
Autometer gauges.
Recaro front seats.
Custom rear seat with front buckets shape molded in!
This car has not been molested and still running standard boost.
There is probably a heap load of things i am missing but i cant think now as this is depressing to write as i need to sell this car very quickly.
I spent about 10k on the inside and little bits and pieces in the past few weeks so come on guys some1 must want this work of art?
Also the car is engineered for every single nut and bolt!
im looking at offers of about 20 or so
pics as follows:
:laugh:
Edited by mrhele
https://www.sau.com.au/forums/topic/132675-moddified-show-r33-gts-must-go/
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
