Jaycar Boost Controller,Fuel Adjuster,Turbo Timer
Been getting more and more PM's about when another group buy is gonna be on for these items from the last one... so I'm gonna be organising it while I have a little free time on my hands.
These are the kits discussed here:
http://www.skylinesaustralia.com/forums/in...showtopic=61207
The previous group buys I've done for these are here:
http://www.skylinesaustralia.com/forums/in...showtopic=66908
and here:
http://www.skylinesaustralia.com/forums/in...showtopic=74872
Prices are as follows (I've posted the prices depending on how many we get... eg if at the end of the group buy, I only have to order 1 EBC, then it'll be more expensive than 3 EBC's etc). All prices include GST.
Independent Electronic Boost Controller
http://www1.jaycar.com.au/productView.asp?ID=KC5387
RRP - $80
Group Buy Prices:
1 to 2 - $62
3 to 4 - $58
5 plus - $53
Digital Fuel Adjuster
http://www1.jaycar.com.au/productView.asp?ID=KC5385
RRP - $80
Group Buy Prices:
1 to 2 - $62
3 to 4 - $58
5 plus - $53
Hand Controller for Digital Adjusters
http://www1.jaycar.com.au/productView.asp?ID=KC5386
RRP - $60
Group Buy Prices:
1 to 2 - $48
3 to 4 - $43
5 plus - $40
RS232 (Parallel Port) Connecting Cable Computer Lead for Controller - 1.8m
http://www1.jaycar.com.au/productView.asp?ID=WC7502
RRP - $8.35
Group Buy Prices:
1 to 10 - $6
10 plus - $5
Intelligent Turbo Timer
http://www1.jaycar.com.au/productView.asp?ID=KC5383
RRP - $45
Group Buy Prices:
1 to 2 - $35
3 to 4 - $33
5 plus - $30
Digital Pulse Adjuster
http://www1.jaycar.com.au/productView.asp?ID=KC5384
RRP - $80
Group Buy Prices:
1 to 2 - $62
3 to 4 - $58
5 plus - $53
Performance Electronics for Cars - Silicon Chip Publications
http://www1.jaycar.com.au/productView.asp?ID=BS5080
RRP - $20
Group Buy Prices:
1 plus - $19 (w00t!)
If there's anything else from Jaycar that you'd like to add to your order ask and I'll get a price for you. Please reply with what you'd like in this thread, and feel free to ask any questions. In the past group buy guys have also ordered soldering irons and solder etc, which you'll need to put these kits together.
Please post which item you'd like, and what quantity. I'll set the cutoff for this group buy for the 17th of September (that's 2 weeks from now).
I found that shipping cost is around $10 across australia for a parcel post pack that holds most of these items. If you're in Sydney, then you can pick it up from me at a meet or something like that if you want to save on the shipping costs.
As soon as you reply with item name and quantities I'll PM you guys payment details and costs (you should be able to add them up yourself from the costs I've posted, but I'll PM you a total to confirm).
I'm closing this group buy on Sunday so I can put the order in first thing on Monday and hopefully have them shipped to you by Tuesday, for arrival by Friday... I hope. :laugh:
Deadline extended to the 1st of Oct
  • Replies 236
Put me down for:
1 x Independent Electronic Boost Controller
1 x Hand Controller for Digital Adjusters
1 x RS232 (Parallel Port) Connecting Cable Computer Lead for Controller - 1.8m
thanks
Put me down for:
thanks
Put me down for the same...
Put me down for:
thanks
same for me thanks.
There's no way for the Turbo timer to have a default time setting?
I don't think there is... unless you set the max idle time to however long you want, and then just put the sensitivity to max, so it thinks you need max idle all the time regardless of how hard you've driven it.
2 days to go people... the numbers look promising.
ducki, post up which iron and solder you're after (there's a few options) and I can give you a price on it. I get below retail on all of em, so just find the product code on the Jaycar website and post it up.
void, I'll be PM'ing everyone payment details shortly once we finalise numbers (just realised I said I was going to do it as soon as you posted a response... whoops).
ducki - have a look at the kit TS-1650, has a 25w iron (fine for pcb soldering), a stand, solder and solder wick for RRP$20
...it's an easy budge kit, I'm figuring if you don't have an iron you probably don't do this all the time so why spend a fortune!?
just a thought.
and f/m - cheers, just wasn't sure if I needed to chase that up to be part of the g/b or not... thanks
Edited by Mr Void
thanks for the suggestion Void. if this iron can be used to make this boost controller.. then put me down for the TS-1650 .. just thinking.. is the tip of the iron abit too big to solder or am I just seeing things?
QTY - 6 @ $53 each
QTY - 1 @ $62 each
QTY - 5 @ $40 each
QTY - 3 @ $6 each
Soldering Kit (TS1650)
QTY - 1 @ $15.50 each
Mr Void, just wanted to make sure that you don't want a hand controller? You'll need it to set the EBC and DFA you've requested.
ducki the iron that comes as part of this kit is the Duratech 25W (TS1465)
and comes with this tip:
it should be OK for PCB soldering.
I'll be PMing each of you guys that responded in this thread your totals including shipping and payment details later today.
If anyone would like anything else from Jaycar, please let me know by the end of the day today.
QTY - 6 @ $53 each
QTY - 1 @ $62 each
QTY - 5 @ $40 each
QTY - 3 @ $6 each
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
