Hi all
I've got a R32 gts-4 it has a jet speed FINAL KONNEXION Body-Kit but I don't like the look of the side skirts . I've looked around and found a set that I like on carmate.com. Has any got them or other kits from them what do you think and how do they fit?
https://www.sau.com.au/forums/topic/132726-carmatecom-body-kits-need-info/
ive delt with jetspeed and carmate
jetspeed sent me the wrong parts, took me 4months to get my money back, they didnt even send the correct sum of cash back to me, they sent LESS, and i couldnt be bothered arguing after 4months.
carmates body kits came to me, damaged, didnt fit, like it was off a completely different car,i took to them, they tried to fix it and f**ked it up, which i had to wait a week for them to refibreglass it, i could of fixed it my self, but when i pay for something to fit on a car, i expect it to.
i wont be buying anything off them again lol
i havnt delt with carmate...but alot of ppl say they are good...and some....(like above) say they are absolutely rubbish.
if i was u i would call them up and make em garentee perfection in their products.
better yet fax them a contract stating they will pay for all damaged goods which u aint at fault for. get them to sign it...and fax a copy back to u.
wat can u lose huh:)
I bought a 32gtr copy for my gtst from Carmate. Guys were really friendly. Had to do some minor adjustments here and there but all in all i was happy with the way it turned out. Only 300bucks, you get what you pay for and for what i wanted at the time it was perfect.
I got a 400R front bar from them. It fit nicely although had to be cut out so that the intercooler piping would fit. This isnt poor quality of the bar - its just the design of my piping. I'm happy with the quality, its relatively strong, and hasnt cracked up in some particularly harsh conditions.
haha i'll second that, seen his kit. it's mad.. strong mofo withstand a truck :)
haha i'll second that, seen his kit. it's mad.. strong mofo withstand a truck :P
lol... :)
(a fool backed into me with a truck the other day.. luckily it just dented the bonnet and didnt destroy the front bar!)
Bodykits are a touch and go thing, they are fiberglass and come out of moulds. The moulds do suffer from wear and tear.
I have brought many products from carmate for both myself and clients and I have never had a problem.
Bodykits are not a direct bolt on product theres always some kind of modifying.
It took 8 kilos of resin to fit my all the gear to my car, but it was my car.
My advice to you guys, unless you know what you are doing have your kit fitted professionaly and let them buy the kit! They should know who are distrubuting good kits.
If anyone has problems with kits please pm I will help solve your problems.
yup. and if you can't, thats wrong. a kit should be made to fit the car it is intended for perfectly. no if's but's or maybes.
maybe they should call the copy kits 'almost bodykits'. Seems not many people ever get perfect copy kits or maybe its just those who don't get a good kit end up venting their frustration on here / ns etc.
Edited by kursed
I purchased a front lip from CarMate... didn't really care about the quality or the fitment as we would've "made it fit"...
I needed it purely to protect my OEM front bar from anymore driveway damage - the OK product I received was a bonus.
Gotta say, I agree.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
