Regretful sale-moving
Nissan r32 gts-t type M Manual gun metal grey 92-93 spec (late 92 model)
This is an A1 example of an r32 not a ratty accident repaired car.
Only aussie owner.Imported 3 years ago personally.
Positives:
Engine idle's like a lexus,never thrashed,NEVER driven hard.Yes i drive like an old man... :ermm:post-21850-1157596097.jpgpost-21850-1157596553.jpg
My mates S15 engine sounds like a truck compared to mine!
Mods done in japan:
HKS pod filter
Cat back exhaust and top of the line muffler.(forgot the weird japanese brand)
Genuine Full GTR bodykit including rear wing-not a crappy imitation bar
GTS rear pods
Dark window tints
Raybrig fog lights with remote control!
Mods done here:
Full Tein hr coilovers
Dump pipe
High flow cat
Front sway bar
Front adjustable castor arms
5 spoke rare 17'' rims: a-tech monoblocks with falken alpha rs tyres made in japan
Brand new 2 month old heavy duty clutch exeedy
Brand new slave cylinder (clutch)
Brand new master cylinder (clutch)
New timing belt done at 108000kms
New spark plugs
New water pump at same time.
New speedo cable
New optima dry cell battery 3 months ago
Pro sound system install
Machined front discs
Bendix pro pads front,and rear
All electronics and lights etc work flawlessly
Nismo gear shifter
Projector front headlights-easily converted to xenon
Japanese seat belt extension arm-ultra rare!
Had done 90000kms when arrived.Now with 128000 Genuine kms
Always use 98 shell optimax
Allways used NISSAN 7.5W 30W oil and oil filter
Just serviced.
New airconditioner r34a gas and pipes/condenser
Full imobiliser with keyless entry tracker
Recipts to back up.
Negitives:
Small stone chips on front bar ( barley noticeable)
One of the best examples of a 32 gtst (if i do say so myself)
Asking 15,000 O.N.O
Genuine offers and intersest welcome,NO TEST PILOTS or tyre kickers,i dont have the time or insurance cover for this.Just give me a call to arrange a time.Details in post below.
Edited by cookie--monster
https://www.sau.com.au/forums/topic/133323-sold/
sure has...i will be renewing it in late december...if i still have it by then-i just put it on car sales and have had a very intrested buyer.i put the price down too.
will take off rims and stereo to lower it further still if needed.
https://www.sau.com.au/forums/topic/133323-sold/#findComment-2583252
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
