Gb: R32, R33, R34 Skyline Carbon Fibre And Fibreglass Bits
  • Replies 272
Rflirty4 added to the list... just awaiting confirmation of stock first.
All the others in Order #2; your stuff is en-route now, sorry for the delay.
Well he said he's just waiting for a moment to get to the post office over there - it only takes a few days after that and I'll be sending everyone's stuff express once it's here!
OK I got an answer for the CF boot lid... you can get these in the following "colours":
Black CF (what we usually see in AUS)
Silver CF
Blue CF
Price I've been told is approximately $1k + freight... they are as per the photos posted on page 1. Obviously a few things will need to be transferred over (stop light, locks, latches etc)
Personally, I wouldn't bother unless you're made of gold.
Silver CF
Blue CF
any idea on freight cost?????? cause i really dont mind paying $1000 for the boot lid itself (as there is only one guy in australia that i have had an answer back on and said he can do it but he wants up front payment before making it and sound a bit dodgy eg. no pick up and bank deposit only even though he is in sydney and close to me!!!!)
maybe if more ppl want them we can split the freight costs?
and by the way im after black cf
thanks
Justin
Cost of freight will depend on the way we send it... obviously it will need to be packed very well; insured and tracked - these three items don't come cheap; add on more if you want it in a hurry too.
I will dummy up some numbers :P
thanks
i would appreciate that heaps, if other ppl are interested in these boot lids for r34 please voice your interests now and we maybe able to save on the shipping cost...
by the way im not in a huge rush so if i can save on the cost of freight by sending it economy, by boat i dont mind
I'd estimate that by sea; you'd be looking at an extra $100-$150 in freight... those in Sydney can then make the effort to come collect it from me as I really cannot be bothered to lug around a boot lid :) (I'm small, so lay off)
I'd estimate that by sea; you'd be looking at an extra $100-$150 in freight... those in Sydney can then make the effort to come collect it from me as I really cannot be bothered to lug around a boot lid :dry: (I'm small, so lay off)
mate that price of $1000+$100-$150 freight is fine. can you go ahead and order a black cf one for me please. just let me know when you need payment we can meet up and i can pay you in person. and pick up is not a problem.
also is there any chance of getting the boot lid made without the key barrell hole and the middle brake light hole? if so i would appreciate that but if not it doesnt really worry me.
thanks
Justin
0425291404
Justin; I'm not going to promise you anything yet - I will have to get in contact with this guy and ask for confirmation. I don't want to promise something I can't deliver that's all.
If he's all good with it then yeah, we'll go ahead with it ;)
If he's all good with it then yeah, we'll go ahead with it :laugh:
satanic
no problem mate just let me know when confirm. i appreciate your help.
thanks
Justin
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
