When i got my car the right rear disc brake wouldn't go back to its original seating position so the pad and rotor would rub against each other. Being my first car and knowing absolutely nothing about em, I didn't really bother about the little bit of noise coming from the rear end on braking. They developed aREALLY REALLY thick layer of orange rust/brake dust and now im pretty **** off that I didn't look at the problem earlier when it happened. I've done what i can to remove the dust from the rim but it's still in the spokes.
Is there something i can do or some place i can take my rims to to hav this shit removed?
All help is appreciated!
Thanks
Tim
https://www.sau.com.au/forums/topic/13342-my-rims-need-attention/
TIMMMAYYY - thats why I suggested brake cleaner, not totally sure if it will clean the nooks and crannies, but everything I have attacked with it, all the dirt just disappears. If you dont have any and dont want to risk the less than $10 a can will set you back, drop me a pm and you can do a test with a tin I have lying around unemployed.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
