Kalt Baron 50 EC Helicopter For Sale
Never Been Flown Before!!!
Huge Engine
Comes with heaps of spares including NEJ Gryosensor 110 BB with instructions.
Spare rear rotors!
Comes with all servos (eight) but all you need to fly is a remote!!!!!
Original purchased for a university project where a camera was going to be mounted on it.
$1050 ono PRICE DROP $999!!!!
Visit Ebay and make a bid on it!!!
On ebay it is only $550 MAKE A BID
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...E%3AIT&rd=1
[/size]
Contact: [email protected]
post-27955-1157859774.jpgpost-27955-1157859827.jpgpost-27955-1157859850.jpgpost-27955-1157859899.jpgpost-27955-1157859934.jpgsauvic_cams.pdfpost-27955-1157860118.jpgpost-27955-1157860254.jpg[attachmen
Edited by DENI
https://www.sau.com.au/forums/topic/133687-rc-helicopter/
Sorry, I am not exactly sure but as you can see in the pictures the helicopter as a large engine, possibly 50cc I am not exactly sure and it only weighs around 4kg.....do the maths. It was original purchased for a university project where a camera was going to be mounted on it and used for surveillance so it can deffinetely support alot of weight.
Cheers, Daniel.
https://www.sau.com.au/forums/topic/133687-rc-helicopter/#findComment-2477885
