Arias Pistons 5 perfect one damaged
6 week wait from states for new one around $300
set of 5 a 1 bung one $750 0.5 over bore suit rb26 only
Aftermarket R32GTR only GAB shocks and springs semi low set 4 very good cond $450
like new harmonic balancer suit rb20 only new $300 sell $100
m in south australia near Tea tree plaza
please call 0415 344 630
Edited by SIR032GTR
https://www.sau.com.au/forums/topic/133974-assorted-skyline-parts/
3 ribs on all why would you ask if they are four ribs?
did nissan ever make a 4 rib? thats a pretty wide power steering belt ?
as far as kms who knows the condition is very good though and suits only rb20 det engines possibly non turbo also unsure
as far as indicators they look to be sold
ill confirm soon
Cheers Everyone
ill confirm soon
Cheers Everyone
Most r32gtst power steer pulleys are 4 rib for the hicas pump.
I think i see the confusion
The belt has four ribs and the pulley will suit so it has three ribs as such to match the four ribbed belt
it does fit a rb20det and had the same for alternator and air con etc
hope this clarifys
unknown kms in very good condition
centre bore clean and no cracks
When the guys put my car back together within half an hour a part of the valve guides
broke fell in and crushed between piston and head all fixed now but needed one piston only so
ended ordering 6 to save on time which did not in the end but now i have 5 spare dooh!!!
some one will need them and can order one to mate up a set from USA takes 4 weeks and
around $250 so full set of forgies will cost you $1000 instead of $1399
Edited by SIR032GTR
  • 1 month later...
  • 2 months later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
