Hi im trying to test the timer, can you tell me which wires to connect to what to test it outside the car and also does the handbrake wire need positive or negative power and what is the acc wire for.
Edited by RB SANDY
https://www.sau.com.au/forums/topic/134092-hks-turbo-timer-help/
Thanks. :sick:post-28604-1158105646.jpg
Blue: Accessories Power on
Red: Constant Power even when key is off
Yellow: Ignition Key on
Long white one: Handbrake
Black: Earth
Im pretty sure this should work for you, its what came with my PIVOT TT, and im also pretty sure the handbrake has 12V when its up...but not 100%.
