I just got my car back recently, noticed a few things wrong with it.
Feels like its struggling and on 5 cylinders.
Before someone says coilpack it struggles throughout the rev range, low and high rpm.
I have gotten it back from the panelbeater since I got a respray. I also got them to install my fmic and highflow turbo.
Once I got it back I noticed that my turbotech boost controller was missing its spring, they must have opened it and lost it.
I have the usual mods like full 3" exhaust, front/dump, remapped ecu.
What is the worst thing that could happen if the boost controllers spring is missing?
I have removed it and put it back to the stock setup, still that didn't solve the struggling engine problem.
And when the boost controller was on or even the stock setup, on the boost guage it wont even go above 0. Its like its restricted from going past it because when you drive it, the gauge will quickly go to 0 then stop there.
Does anyone have any ideas?
The last resort I want to do is to give it to a specialist and all he would probably do is to go through the whole list of a 100k service to figureout the problem. Well thats what the panelbeater told me to do anyways, It might just need a tune
https://www.sau.com.au/forums/topic/134316-stock-boost-gauge-wont-go-past-0/
ok this is most likely a very simple fix
firstly, with the boost controller having no spring it essentialyl is working as stock. the spring is what makesthe boost what it is!
now for the rough runnign and no boost.. options as to what it is:
- intercooler hose loose / clamp on too loose
- intercooler hose with a crack in it
- AFM giving problems
what to do?
first, try cleaning the inside of the AFM with a few sprays of brake cleaner
next, take a torch and look over the car at the intercooler clamps to make sure all the hoses are on right. check in the front bar too and thay are hard to see.. most likely that this is the problem...
best of luck,
Warren
Firstly if a coilpack fails completely can miss anywhere in the rev range. Is the engine receiving boost? The Gauge will do that when the turbo is making no boost or its not getting to the engine.
what to do?
best of luck,
Warren
Thanks Warren,
I am waiting on another turbotech boost controller. I was wondering since I'm just missing the spring could I just get a spring from the hardware store or is there special tensions to the turbotech ones?
I will have a look at the intercooler and fmic hoses soon.
I'll get back to you once I check.
Thanks, mate
If you replaced the boost controller with the stock one and you still had the problem then clearly its not the boost controller. Firstly like warren said check all the intercooler piping connections. It sounds to me that your engine is not receiving boost. Without boost a gauge will read as you described.
Hey So Godzilla32,
I just checked the intercooler piping, I just tightened the hoses to its limit. There seems to be no cracks on the hoses either so I guess it could be the afm?
I only checked by revving it, but now I get that fluttering sound which is normal, even though I have the stock setup and panel filter, most likely the intercooler just made it louder.
Although it sounds all normal, does this still mean that the engine isn't getting boost?
Only revved it(no driving) the boost gauge still didn't go past 0 mark. I know only way to check though is to drive it because it shouldn't go over 0 in the 1st place on neutral right?
make sure that the AFM's connected up, i forgot it once and it was bearly running, ideally u should take it back to the ppl that dont the cooler and turbo, n say what the hell have you done, n get them to fix it
I was thinking this too. I wouldnt have driven very far before doing a u-turn...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
