Does anybody knows how to get into contact with nengun? aother than emails. Its been 2 weeks a few emails but no replies IMtrying to purchase powerfc and a boost controller. THanks people
They are slow, but they will get to you eventually, they are not set up to answer questions, especially technical ones. They are simply a reseller, they don't really have stock, they just source whatever you order, once you have paid for it.
Personally I never bother emailing them with questions. I just order what I want, pay the money and it always turns up.
:laugh: cheers :)
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499394
:O cheers :sick:
if thats the case for me which one of the power Fc should i order w/ hand controller and the boost controller? BCNr32,33,34? for my 260rs Let me know thanks
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499509
im 99% sure 32 and 33 use the same ones from memory. u would need a r33 gtr one, as the 260rs's use r33 gtr running gear :sick: best to get a few opinions as im not 110% sure :O
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499530
im 99% sure 32 and 33 use the same ones from memory. u would need a r33 gtr one, as the 260rs's use r33 gtr running gear :O best to get a few opinions as im not 110% sure :O
yeah I said via msn Im 99.95 % sure Yudi needs the R33 GTR Powerfc
Im positive the 260RS for 1997 and 1998 and 1999 etc were based on the R33 and N0T the R34, like how the Series 1 RS4 is based on mainly :O the R33 GTs-T, and unlike the Series 2 RS4 which has components based on the R34 GT-T.
if it was me - Id ask a few questions to ppl on this great forum, and order the R33 GTR PowerFC............ she'll eventually crank over :sick:
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499628
if it was me - Id ask a few questions to ppl on this great forum, and order the R33 GTR PowerFC............ she'll eventually crank over :O
:sick: eventually crank over. yea i pmed RBNT for it. so... waiting.
What will i do without this forum :O
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499710
ok guys BCNR33 is the code for R33GTR? if so i got it right? Then bosst controller theres a few models to choose in Nengun website which ones? They all say to suit power Fc!!! but theres different codes for each ones
415-A001
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A002
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A003
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A008
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A013
AU $ 351.91
AU $ 388.83
To Suit PowerFC
G73GK-TK126
AU $ 351.91
AU $ 388.83
To Suit PFC SW20 Verson 1
let me know guys
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2500532
Heres some info for ya'all :)
The R32 GTR(BNR32) and R33 GTR(BCNR33) use the same PFC.
The 260RS uses the same PFC as the R32/33 GTR.
The boost control kit to suit this PFC is part#415-A001.
Honestly, Nengun are cheap but slow. Expect to wait about 3-5 weeks for your order.
Greenline are a bit dearer but a bit quicker. Expect to wait about 2-3 weeks for your order.
I can do the same deal for $1400 delivered within 5-10 days.
Thought there'd be some SAU members showing a bit of support for SAU traders :(
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2500681
support is good performance wise but sometimes money talks :( i know u do it legit with taxes and gst, but people want the most goods for the least money even if they have to wait.
i'd pay another $100 for the quick delivery, but no more or i'd just goto greenline.jp
sorry PW just saying it like it is... no offence to your prices etc as they seem very reasonable for an australian business :)
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2500870
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
