Does anybody knows how to get into contact with nengun? aother than emails. Its been 2 weeks a few emails but no replies IMtrying to purchase powerfc and a boost controller. THanks people
They are slow, but they will get to you eventually, they are not set up to answer questions, especially technical ones. They are simply a reseller, they don't really have stock, they just source whatever you order, once you have paid for it.
Personally I never bother emailing them with questions. I just order what I want, pay the money and it always turns up.
:laugh: cheers :)
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499394
:O cheers :sick:
if thats the case for me which one of the power Fc should i order w/ hand controller and the boost controller? BCNr32,33,34? for my 260rs Let me know thanks
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499509
im 99% sure 32 and 33 use the same ones from memory. u would need a r33 gtr one, as the 260rs's use r33 gtr running gear :sick: best to get a few opinions as im not 110% sure :O
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499530
im 99% sure 32 and 33 use the same ones from memory. u would need a r33 gtr one, as the 260rs's use r33 gtr running gear :O best to get a few opinions as im not 110% sure :O
yeah I said via msn Im 99.95 % sure Yudi needs the R33 GTR Powerfc
Im positive the 260RS for 1997 and 1998 and 1999 etc were based on the R33 and N0T the R34, like how the Series 1 RS4 is based on mainly :O the R33 GTs-T, and unlike the Series 2 RS4 which has components based on the R34 GT-T.
if it was me - Id ask a few questions to ppl on this great forum, and order the R33 GTR PowerFC............ she'll eventually crank over :sick:
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499628
if it was me - Id ask a few questions to ppl on this great forum, and order the R33 GTR PowerFC............ she'll eventually crank over :O
:sick: eventually crank over. yea i pmed RBNT for it. so... waiting.
What will i do without this forum :O
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499710
ok guys BCNR33 is the code for R33GTR? if so i got it right? Then bosst controller theres a few models to choose in Nengun website which ones? They all say to suit power Fc!!! but theres different codes for each ones
415-A001
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A002
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A003
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A008
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A013
AU $ 351.91
AU $ 388.83
To Suit PowerFC
G73GK-TK126
AU $ 351.91
AU $ 388.83
To Suit PFC SW20 Verson 1
let me know guys
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2500532
Heres some info for ya'all :)
The R32 GTR(BNR32) and R33 GTR(BCNR33) use the same PFC.
The 260RS uses the same PFC as the R32/33 GTR.
The boost control kit to suit this PFC is part#415-A001.
Honestly, Nengun are cheap but slow. Expect to wait about 3-5 weeks for your order.
Greenline are a bit dearer but a bit quicker. Expect to wait about 2-3 weeks for your order.
I can do the same deal for $1400 delivered within 5-10 days.
Thought there'd be some SAU members showing a bit of support for SAU traders :(
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2500681
support is good performance wise but sometimes money talks :( i know u do it legit with taxes and gst, but people want the most goods for the least money even if they have to wait.
i'd pay another $100 for the quick delivery, but no more or i'd just goto greenline.jp
sorry PW just saying it like it is... no offence to your prices etc as they seem very reasonable for an australian business :)
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2500870
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
