Does anybody knows how to get into contact with nengun? aother than emails. Its been 2 weeks a few emails but no replies IMtrying to purchase powerfc and a boost controller. THanks people
They are slow, but they will get to you eventually, they are not set up to answer questions, especially technical ones. They are simply a reseller, they don't really have stock, they just source whatever you order, once you have paid for it.
Personally I never bother emailing them with questions. I just order what I want, pay the money and it always turns up.
:laugh: cheers :)
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499394
:O cheers :sick:
if thats the case for me which one of the power Fc should i order w/ hand controller and the boost controller? BCNr32,33,34? for my 260rs Let me know thanks
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499509
im 99% sure 32 and 33 use the same ones from memory. u would need a r33 gtr one, as the 260rs's use r33 gtr running gear :sick: best to get a few opinions as im not 110% sure :O
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499530
im 99% sure 32 and 33 use the same ones from memory. u would need a r33 gtr one, as the 260rs's use r33 gtr running gear :O best to get a few opinions as im not 110% sure :O
yeah I said via msn Im 99.95 % sure Yudi needs the R33 GTR Powerfc
Im positive the 260RS for 1997 and 1998 and 1999 etc were based on the R33 and N0T the R34, like how the Series 1 RS4 is based on mainly :O the R33 GTs-T, and unlike the Series 2 RS4 which has components based on the R34 GT-T.
if it was me - Id ask a few questions to ppl on this great forum, and order the R33 GTR PowerFC............ she'll eventually crank over :sick:
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499628
if it was me - Id ask a few questions to ppl on this great forum, and order the R33 GTR PowerFC............ she'll eventually crank over :O
:sick: eventually crank over. yea i pmed RBNT for it. so... waiting.
What will i do without this forum :O
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499710
ok guys BCNR33 is the code for R33GTR? if so i got it right? Then bosst controller theres a few models to choose in Nengun website which ones? They all say to suit power Fc!!! but theres different codes for each ones
415-A001
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A002
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A003
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A008
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A013
AU $ 351.91
AU $ 388.83
To Suit PowerFC
G73GK-TK126
AU $ 351.91
AU $ 388.83
To Suit PFC SW20 Verson 1
let me know guys
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2500532
Heres some info for ya'all :)
The R32 GTR(BNR32) and R33 GTR(BCNR33) use the same PFC.
The 260RS uses the same PFC as the R32/33 GTR.
The boost control kit to suit this PFC is part#415-A001.
Honestly, Nengun are cheap but slow. Expect to wait about 3-5 weeks for your order.
Greenline are a bit dearer but a bit quicker. Expect to wait about 2-3 weeks for your order.
I can do the same deal for $1400 delivered within 5-10 days.
Thought there'd be some SAU members showing a bit of support for SAU traders :(
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2500681
support is good performance wise but sometimes money talks :( i know u do it legit with taxes and gst, but people want the most goods for the least money even if they have to wait.
i'd pay another $100 for the quick delivery, but no more or i'd just goto greenline.jp
sorry PW just saying it like it is... no offence to your prices etc as they seem very reasonable for an australian business :)
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2500870
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
