Does anybody knows how to get into contact with nengun? aother than emails. Its been 2 weeks a few emails but no replies IMtrying to purchase powerfc and a boost controller. THanks people
They are slow, but they will get to you eventually, they are not set up to answer questions, especially technical ones. They are simply a reseller, they don't really have stock, they just source whatever you order, once you have paid for it.
Personally I never bother emailing them with questions. I just order what I want, pay the money and it always turns up.
:laugh: cheers :)
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499394
:O cheers :sick:
if thats the case for me which one of the power Fc should i order w/ hand controller and the boost controller? BCNr32,33,34? for my 260rs Let me know thanks
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499509
im 99% sure 32 and 33 use the same ones from memory. u would need a r33 gtr one, as the 260rs's use r33 gtr running gear :sick: best to get a few opinions as im not 110% sure :O
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499530
im 99% sure 32 and 33 use the same ones from memory. u would need a r33 gtr one, as the 260rs's use r33 gtr running gear :O best to get a few opinions as im not 110% sure :O
yeah I said via msn Im 99.95 % sure Yudi needs the R33 GTR Powerfc
Im positive the 260RS for 1997 and 1998 and 1999 etc were based on the R33 and N0T the R34, like how the Series 1 RS4 is based on mainly :O the R33 GTs-T, and unlike the Series 2 RS4 which has components based on the R34 GT-T.
if it was me - Id ask a few questions to ppl on this great forum, and order the R33 GTR PowerFC............ she'll eventually crank over :sick:
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499628
if it was me - Id ask a few questions to ppl on this great forum, and order the R33 GTR PowerFC............ she'll eventually crank over :O
:sick: eventually crank over. yea i pmed RBNT for it. so... waiting.
What will i do without this forum :O
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2499710
ok guys BCNR33 is the code for R33GTR? if so i got it right? Then bosst controller theres a few models to choose in Nengun website which ones? They all say to suit power Fc!!! but theres different codes for each ones
415-A001
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A002
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A003
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A008
AU $ 351.91
AU $ 388.83
To Suit PowerFC
415-A013
AU $ 351.91
AU $ 388.83
To Suit PowerFC
G73GK-TK126
AU $ 351.91
AU $ 388.83
To Suit PFC SW20 Verson 1
let me know guys
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2500532
Heres some info for ya'all :)
The R32 GTR(BNR32) and R33 GTR(BCNR33) use the same PFC.
The 260RS uses the same PFC as the R32/33 GTR.
The boost control kit to suit this PFC is part#415-A001.
Honestly, Nengun are cheap but slow. Expect to wait about 3-5 weeks for your order.
Greenline are a bit dearer but a bit quicker. Expect to wait about 2-3 weeks for your order.
I can do the same deal for $1400 delivered within 5-10 days.
Thought there'd be some SAU members showing a bit of support for SAU traders :(
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2500681
support is good performance wise but sometimes money talks :( i know u do it legit with taxes and gst, but people want the most goods for the least money even if they have to wait.
i'd pay another $100 for the quick delivery, but no more or i'd just goto greenline.jp
sorry PW just saying it like it is... no offence to your prices etc as they seem very reasonable for an australian business :)
https://www.sau.com.au/forums/topic/134460-nengun/#findComment-2500870
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
