Easternats
I didn't even see the dyno challenge or the street drags. saw a few burnouts and go to whoa. The cruising on the track was awesome. They pulled us off the track just when we had a good line up of cars - there was me, then a white R34 GTR a couple of R33's & R32's and some VL Turbos. I was spewing - wanted to see how I went with the R34.
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-292719
  • Replies 78
Guest INASNT
The dyno comps at easternats are always crap, the finals were meant to be on sunday at around 12-4 but no 1 showed up!
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-292721
Well I assumed all power figures were rear wheel, the owner said it was loosing traction on the dyno so they only rev it to 7000rpm and not 9000, the car has produced it's best figure of 680rwhp and 580awhp in QLD, apparently all work was done by SUBZERO his bro-in-law, lucky boy.
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-293663
hi guys im the guy with the GTR R34, the white one...it was sure very fun..i was there sat and sun, saw u BIGPSI, we even spoke....;) saw more skylines out there. On saturday there was a R32 GTR that was pretty good too, besides the 32 there werent any GTR's...;)
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-294437
Guest INASNT
saw your car run in the street drags and when u won those races the people in the grandstand were cheering u (I was standing on the bottom level), i was surprised as u beat holdens and fords and those guys love their holdens and fords.
What can u pull down the 1/4?
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-294882
Guest INASNT
im not sure how fast it does 1/4 miles but the corolla with the v8 engine i dragged does it in mid to high 10's, so it should be around there i guess...
hmm that corolla didnt look or sound like a 10 second car. U r gonna have to be packing some serious turbos and other mods to be in the 10 second bracket in your 34.
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-297803
that corolla with the big 8 would be around 1000 kg's i'd imagine.
power to weight it would have the edge over most street cars.
gtr-34 what mods you got done to your beast.
i saw you drive through the tunnel and take off up the first straight. very nice, and you did get cheers when you won, but you also got cheers when you lost. hehe.
cars looks mad though, and if you dont mind telling us, how fast did you get up the main straight, you over took most people from what i could see.
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-297816
Went to Easternats on Sunday too, great day to be out. Saw the R34 GTR and actually had a chat to him in the car park. Good effort though, a 'P' plater driving an R34 GTR.
He told me that his car is standard except for full exhaust, filters and boost (14psi).
Come to calder next Friday GTR R34 like you said you would, I wanna see you pull a ten second pass......
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-297848
no i believe a corolla with a rotary or something in it will do 10's easily enough just because of the weight..
An R34 GTR is definitely rocket fast.. I'd never say it wasn't. To do 10's it still needs a fair amount of mods however... What has yours had done to it GTR-34 ?
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-299570
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
