G'day gents and ladies,
At last, I've given up on the stock car and started with a few mods. It's addictive! I just wanted to ask anyone out there if an ecu would be the next logical step...
I have a HKS 3" cat back; and a K&N high flow panel filter. The difference is awesome (my wife hates me more now). Everything else is stock at the moment.
Should I go for a FMIC and front pipe first before getting something like a Apexi Power FC?
Thanks guys. Look forward to soaking up on your words of wisdom.:uh-huh:
https://www.sau.com.au/forums/topic/13469-would-an-ecu-b-e-the-next-step/
I'd put in the aftermarket ECU after you have upgraded pretty much everything else.. but even if you don't its going to provide useful gains.
You can up the boost to around 10psi without a FMIC for good power gains if you haven't already.
I think though in the R34 the stock computer is a fairly decent unit anyway, and gives good performance, compared to some of the R33's and R32's where good gains can be had in adjusting the ECU.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
