hey guys need some help on this subject. i'm planning to take my car onto the track sometime in the near future but have heard from people that the gtr's oil sump is not up to the job. they told me that the gs i pull on the track would starve a part of the engine of oil thus resulting in a blown engine, possibly with piston coming out of side of block. pls advice if this is true. and if it is true, what can i do to rectify this, other than changing the sump?
thanks.
https://www.sau.com.au/forums/topic/13531-oil-sump/
Justjap have a sump which fixed this problem. 550.
www.justjap.com
I don't have one but have taken the car out on the track on several occasions. It doesn't seem to bother the motor too much. Keep an eye on temps cause gtr's get hot real quick. oil cooler is a must, radiator if things are very bad.
https://www.sau.com.au/forums/topic/13531-oil-sump/#findComment-263570
i think the engine sits on the cross member thing that's y u have to pull the whole engine out.
got quoted 1k just to get the engine out...not a cheap exercise.
another thing, would it be ok if i didn't flog my car around the corners as hard? just wanna get some track time in n if the track work starts getting serious then i'd put the sump in.
is that risky?
https://www.sau.com.au/forums/topic/13531-oil-sump/#findComment-266989
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
