hey guys need some help on this subject. i'm planning to take my car onto the track sometime in the near future but have heard from people that the gtr's oil sump is not up to the job. they told me that the gs i pull on the track would starve a part of the engine of oil thus resulting in a blown engine, possibly with piston coming out of side of block. pls advice if this is true. and if it is true, what can i do to rectify this, other than changing the sump?
thanks.
https://www.sau.com.au/forums/topic/13531-oil-sump/
Justjap have a sump which fixed this problem. 550.
www.justjap.com
I don't have one but have taken the car out on the track on several occasions. It doesn't seem to bother the motor too much. Keep an eye on temps cause gtr's get hot real quick. oil cooler is a must, radiator if things are very bad.
https://www.sau.com.au/forums/topic/13531-oil-sump/#findComment-263570
i think the engine sits on the cross member thing that's y u have to pull the whole engine out.
got quoted 1k just to get the engine out...not a cheap exercise.
another thing, would it be ok if i didn't flog my car around the corners as hard? just wanna get some track time in n if the track work starts getting serious then i'd put the sump in.
is that risky?
https://www.sau.com.au/forums/topic/13531-oil-sump/#findComment-266989
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
