my new car
Guest Boxhead
ok as you prolly all know, i got a new car, its nice, ok very nice, havent turned it on yet as i looked at it late..
from what i gathered tonight mods are as follows
blitz fmic
cusco front strut bar
nismo rear strut bar
m's K&N pod filter
big exhuast(big to me, could just be 3') - not sure brand
stock interior
Tein coilovers
timing belt done just at 99 kms..
so.. i have some things to do, interior needs a good detail
tryin to post pics, but i think they might be too big.. so will resize and add
https://www.sau.com.au/forums/topic/13556-my-new-car/
Guest Boxhead
im not sure megalla, but it is dead quiet everywhere haha, it will get a good rev or two tomorow :D here are first pics
engine bay
exhuast 1
exhuast2
blitz fmic
rear struts
i couldnt get pics of suspension, coz i guess its set too low for me to really get camera in there etc...
oh also, i forgot, the front brake rotors are slotted :D
https://www.sau.com.au/forums/topic/13556-my-new-car/#findComment-264239
Guest Boxhead
ok little update, through suggestions of other people, with me showing pics, the front pipe seems to be aftermarket...
yes i turned the car on, sounds very nice...the suspension is height adjustable..
also i have a switch wired to the ecu, but the back of it, here is the pic
http://www.lexicon.net/julieelliott/car/car%20005.jpg
thats where in enters the ecu.. anyone have any idea what it is?
https://www.sau.com.au/forums/topic/13556-my-new-car/#findComment-265400
Guest Boxhead
Guest 87vlt
I think that adjusts your idle. My VL(s) have one - nissan ecu and all ....
Also dude you need and extra 0 in your links ....
https://www.sau.com.au/forums/topic/13556-my-new-car/#findComment-265484
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
