my new car
Guest Boxhead
ok as you prolly all know, i got a new car, its nice, ok very nice, havent turned it on yet as i looked at it late..
from what i gathered tonight mods are as follows
blitz fmic
cusco front strut bar
nismo rear strut bar
m's K&N pod filter
big exhuast(big to me, could just be 3') - not sure brand
stock interior
Tein coilovers
timing belt done just at 99 kms..
so.. i have some things to do, interior needs a good detail
tryin to post pics, but i think they might be too big.. so will resize and add
https://www.sau.com.au/forums/topic/13556-my-new-car/
Guest Boxhead
im not sure megalla, but it is dead quiet everywhere haha, it will get a good rev or two tomorow :D here are first pics
engine bay
exhuast 1
exhuast2
blitz fmic
rear struts
i couldnt get pics of suspension, coz i guess its set too low for me to really get camera in there etc...
oh also, i forgot, the front brake rotors are slotted :D
https://www.sau.com.au/forums/topic/13556-my-new-car/#findComment-264239
Guest Boxhead
ok little update, through suggestions of other people, with me showing pics, the front pipe seems to be aftermarket...
yes i turned the car on, sounds very nice...the suspension is height adjustable..
also i have a switch wired to the ecu, but the back of it, here is the pic
http://www.lexicon.net/julieelliott/car/car%20005.jpg
thats where in enters the ecu.. anyone have any idea what it is?
https://www.sau.com.au/forums/topic/13556-my-new-car/#findComment-265400
Guest Boxhead
Guest 87vlt
I think that adjusts your idle. My VL(s) have one - nissan ecu and all ....
Also dude you need and extra 0 in your links ....
https://www.sau.com.au/forums/topic/13556-my-new-car/#findComment-265484
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
