my new car
Guest Boxhead
ok as you prolly all know, i got a new car, its nice, ok very nice, havent turned it on yet as i looked at it late..
from what i gathered tonight mods are as follows
blitz fmic
cusco front strut bar
nismo rear strut bar
m's K&N pod filter
big exhuast(big to me, could just be 3') - not sure brand
stock interior
Tein coilovers
timing belt done just at 99 kms..
so.. i have some things to do, interior needs a good detail
tryin to post pics, but i think they might be too big.. so will resize and add
https://www.sau.com.au/forums/topic/13556-my-new-car/
Guest Boxhead
im not sure megalla, but it is dead quiet everywhere haha, it will get a good rev or two tomorow :D here are first pics
engine bay
exhuast 1
exhuast2
blitz fmic
rear struts
i couldnt get pics of suspension, coz i guess its set too low for me to really get camera in there etc...
oh also, i forgot, the front brake rotors are slotted :D
https://www.sau.com.au/forums/topic/13556-my-new-car/#findComment-264239
Guest Boxhead
ok little update, through suggestions of other people, with me showing pics, the front pipe seems to be aftermarket...
yes i turned the car on, sounds very nice...the suspension is height adjustable..
also i have a switch wired to the ecu, but the back of it, here is the pic
http://www.lexicon.net/julieelliott/car/car%20005.jpg
thats where in enters the ecu.. anyone have any idea what it is?
https://www.sau.com.au/forums/topic/13556-my-new-car/#findComment-265400
Guest Boxhead
Guest 87vlt
I think that adjusts your idle. My VL(s) have one - nissan ecu and all ....
Also dude you need and extra 0 in your links ....
https://www.sau.com.au/forums/topic/13556-my-new-car/#findComment-265484
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
