I shouldn't say this, but at an educated guess.
Gold thing goes to wastegate, the other two can be used as either manifold or opened.
Now that I think about it, that picture you uploaded earlier looks shockingly similar to a std soleniod. (Well on the i-R, anyway)
The solenoid is the same as the DSBC Spec S ( the single solenoid version) - surely the guys at Cypher or another performance will know what to hook to what? Ive asked Jordan if he can shed any light on the situation.
Sorry something that should be straight forward is becoming a drama... we will sort it soon :P
ta
Conrad
Poyz it IS the same as the DSBC Spec S solenoid if you have worked with one of them...
do you have the doco on setting one up (or know what hooks to what?)
The DSBC Spec R has that huge dual solenoid box with the in and out connectors labelled clearly.
Ta
Conrad
Downloaded the Japanese manual for the Spec S (got any Japanese mates?) and the piccy for solenoid installation shows the IN line being the bottom steel connection, and the OUT line being the bottom of two plastic connections closest to the body of the solenoid.
I am unsure what the top plastic connection does, but its not shown as either connected or blocked off.
Hope this helps - oh, and make sure you mount the solenoid within 1m of the wastegate (usually where the stock solenoid was is a good mounting point) to keep good response.
Ta
Conrad
Hi adam 32, why don't you just take a guess and connect it up. It isn't gunna harm anything, leave the hoses long enough for swapping and take it for a short drive. Watch the boost guage and swap it around until it works. Take less time than typing posts.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
