for sale is the turbo kit from my skyline in the 'whole cars' section as i am considering selling it as parts
it will fit an rb25/30 with an rb25 head
its a sub zero setup as featured on one of they're customers cars in a previous issue of zoom magazine
the car did a 10.9 1/4 mile with 326rwkw
consisting of..
custom stainless manifold
subzero 40mm wastegate
2x t3/4 turbos (rear housing from vl turbo)
pipes to intercooler
air filters and pipes
braided oil and water lines
all hoses and clamps
stainless dump pipes and Y joint to cat
all u have to do is bolt it on
can see running on car
on my car it produced 356rkw @ 19psi when i ran out of spark
could easily produce over 400rwkw
asking $2000ono. located in western sydney
[email protected] for more info
Edited by kaotik
https://www.sau.com.au/forums/topic/136027-twin-turbo-kit-for-rb2530/
selling any internals? What other parts are needed to get these running?
selling injectors x6 blitz 1000cc top feeds $950 and ill throw in a gtr fuel rail
not selling internals
the whole kit is complete to bolt on, u just need to meet up the cooler piping and exhaust piping and remove ur air cond
