  • 3 months later...
Ive just bought an R34, and the traction control light on the dashboard doesnt come on at all. Even when you operate the switch on the dashboard ( in front of your left knee).
I suppose the traction control prevents 1 wheel slipping more than the other in slippery conditions, and if you dont want the feature you turn it off via the switch on the dashboard, and a light comes on on the instrument panel.............So where can I start to repair this feature?
Im starting to think that a workshop manual is a necessity with this model, but at $650.00, it is a bit steep.
I have just bought a 1999 GTT ER34 as well ... waiting for Compliance to become available again before I import. But I have a translated Japanese manual I bought from www.importdrive.com.au ... it was about $50 I think... for those interested.
As far as I can tell from the book cars fitted with TCS have a button on the left hand side just under the steering wheel to turn the feature on or off (above your left knee as described already).
Also when you have the TCS on No light should be on in the dash. When you turn the system off there will however be a light confirming TCS OFF .... as far as I can tell TCS will do its job in the background when required.
Accrording to the manual when TCS actually kicks in under heavy acceleration the Slip light will flash indicating that the car may slip .... I suppose thats the only evidence of the TCS operating you'll see in the instrument panel.
One good way to check to see if its the globe or the light thats faulty is to check it when you are turning the car on ... as the car is turned on BOTH the TCS OFF light as well as the SLIP light should come on in the dash, after the car has started and if the system is working properly both lights should then go off. If either the TCS OFF light or SLIP light stay on afer starting the car this indictaes a fault in the system ... thats when you need to get it repaired.
Hope that helps
Originally posted by smb35673
Accrording to the manual when TCS actually kicks in under heavy acceleration the Slip light will flash indicating that the car may slip .....
YES, that is exactly what happens!
Btw TCS works by reducing engine power when it detects wheelspin to the driving wheels - in theory it should prevent you from 'burning out' your tyres too but in the wet it can still spin - I have tried it at heathcote whilst doing some 1/4 mile runs...
  • 10 months later...
Sorry to dig up this old post but I've just got a GT-T and noticed that with the TCS on sometimes under hard acceleration the car seems to shudder when accelerating. It starts to accelerate hard then drops revs then goes again then drops revs etc. Doesn't do it with TCS off. I imagine this is just TCS functioning correctly by limiting revs when wheelspin is detected? In this case it will be switched off from now on unless its wet.
Yeah, you got it correct NJR 34GTT, it only drop the rev to prevent the power going from the engine to the wheel so the computer disconnect the power to the wheel due to wheel spin.
So remember to turn off your TCS while you are racing :cheers:. In wet day it's very useful though hehehe.
About boost cut/fuel cut issue I can't really answer that :)
That's from me
Hmmm.... After reading a few other threads I have realised this could also be boost/fuel cut? Since its running 13psi which is supposedly very high for a 34 I suspect this is more likely the issue?
I run mine at 1 bar but I had to fit a fuel defender to be able to do that.Other wise car misses and starves of fuel.
It is a wonder your car is not missing and farting running at 13 lb or do you have a fuel defender fitted.
No running issues at all.
Basic mods on the engine, pretty sure it is the tcs.
as it is happening at quite low revs ~3000-3500rpm as opposed to the higher rpms usually experienced with boost/fuel cut.
As for the fuel defender I am not 100% sure but it was tuned to run as it is with the boost level and has been running it quite happily for over a year now.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
