Wsid
Well, this, but braided line to the sender that is mounted on the chassis. Oil Pressure doesn't need to be close, while I prefer Oil Temp is in the active oil flow (bro science, not sure how much it matters). That's how I've had mine set up for years and it works OK
Welcome back! There is a v series forum, a little quiet at times but every new active member helps
But, per MBS206's question, what happens when it doesn't start. When you turn the key to IGN, do the dash lights come on (then go off after a couple of seconds) - likely alarm or other electrical issue When you turn the key to STRT do you head a clear click (the starter solenoid trying) without the engine turning (likely starter motor)
