I bought this Rear tie rod brace a while back I really need to cash rather than the brace, plus I have no time to fit it. The thing is brand new with brand new rose joints.
$100 posted aust wide
Can arrange pics if 100% necessary...but it looks like this:
Edited by coprims
id also like to know how this fits in. will it fit a hicas type subframe (with hicas lock bar) or is it for non hicas subframes?
even if you have a link to some info that would be grate.
Where exactly does this bolt in i have a a31 wouldnt mind some more wank wank suspension bits
on the cradle where your toe arms bolt together I belive...It uses extended bolts too :angry:
Yes I have confirmed where it bolts up, it basically goes in between your toe arms under the diff, I have not tested this on a hicas equipped car but it should still fit I would think.
Cheers
Matt
Cheers
Matt
Im pretty sure this will only bolt up to a non-hicas cradle.
http://cgi.ebay.com.au/S13-S14-S15-R32-Low...7QQcmdZViewItem
And after checking there, i was right... not sure if that means non-hicas cars as in, non hicas cradle, or if having a lock bar to disable hicas would be enough.
Might be worth messaging roguepi on ebay and sussing it out for some clarifitcation.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
