safety21 bolton 6 point a31/c33 full cage... not visible at all from outside of the car apart from front 2 bars running down the dash... very good for street
$700 quick sale
bride seat price $450
pm's replied to
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
