Time for all you Nigga's to dust off the bluebirds, 120y's and condomodores, Port "G" is back up and running starting on the 6th of November.
Drivers will be charged $30 same as before and spectators will be charged $5 each. Drifting starting from 6pm and going till about 9pm.
We will be having 20 drivers max for every monday night. Please dont try to hassle me or con me to get you in after the 20 as we have to be strict with this and your ear will hurt after I hang up on you. Also if you put your name down and just dont turn up, we will be very hesitant to put your name down again, so please let us know before hand if you cant make it.
So lets make this another fun season of drift, without all the politics and expense of "Drift" as we have come to know it.
Call ryan for bookings on 83467077 ( I know he is very much looking forward to your calls)
p.s no shitboxes out on the track
Edited by Savalas
https://www.sau.com.au/forums/topic/137293-port-g-is-back/
Lovely......... $5 to spectate now, Damn there is gonna be some money made there, going by how many peeps were there by the end of the last summer!
That'll give Ryan something to do during his days won't it???? :laugh:
By the way Terry V your yellow beast was looking quite the tricketo down the Bay the other monday! Good to see it back out! ;)
Edited by Deluxe
https://www.sau.com.au/forums/topic/137293-port-g-is-back/#findComment-2554653
What if they can drift well however have worn paint etc.
In other words do you mean shitboxes going by not being able to do anything on the track or just not looking bling enough?
Edited by Blue Dynamite
https://www.sau.com.au/forums/topic/137293-port-g-is-back/#findComment-2557392
Im prety sure terry just means cars that cant do anything. But do open wheel Skids.
It would be a waste of everyones time if someone has a car that they are just doing burnouts on the track with.
Im gunna enter once my cars ready.
Then Master Ryan can teach me the art of sliding the 4 door.
https://www.sau.com.au/forums/topic/137293-port-g-is-back/#findComment-2557824
this is what he means
couple of times last year a few people showed up in cars that were crap at sliding i.e volvo, rx7 with 308 or something and a corona
if your car looks crap but can slide ok will be happy
look at Tom's old auto bluebird
more than happy to go for a ride round the track with you Brenton to give you a couple of pointers not that I know much ps I think I can only slide 4 doors my silvia's gay
Edited by 1400r
https://www.sau.com.au/forums/topic/137293-port-g-is-back/#findComment-2558130
I've heard about that car actually. Apparently the driver runs a stock engine and has cut springs and that's about it. Also heard he was definitely one of the best out there last time my friend was there that was.
https://www.sau.com.au/forums/topic/137293-port-g-is-back/#findComment-2558500
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
